I'm using the DVI output on the Radeon 9700 pro to output my video to my Sony 65 inch widescreen (HD capable). Actually, I'm using a DVI-D cable since I'll only be using the digital signals. Anyway, my problem is that the "desktop" is too big...all of the sides (top, bottom, both sides) are cut off of the display. When I hook up a normal monitor, everything looks fine.
I've downloaded and installed the latest Catalyst drivers (3.1) and it didn't help. I must be missing a setting somewhere.
Thanks in advance.
Thanks in advance.
