Originally posted by: ribbon13
What's wrong with the suggestions I made 😕
Click the links smart guy.Originally posted by: Dug
Kind of hard to test an Intel 64bit system with AMD hardware.
Intel will have the largest 64bit desktop customer base, so it would make sense to test on that platform. That and we already have an AMD 64bit system to test with.
Still hard to find exactely which motherboards have a BIOS that supports these new cpu's with 64bit OS. Some of the 915's say they do, but many don't. (According to Intel's website.) Asus, MSI, etc don't make it clear either.
Thanks for the link stevty2889. That would be perfect except I forgot to mention I need an ATX motherboard.
I did and I appreciate the links. I went to the Soltek website. Again no mention of EMT64T support. Which is why I said some of the 915's do and many don't, smart guy.
I know ribbon13 was kidding with the comment about AMD, but I put in why so I don't get any more AMD comments.
Simple. Build a AMD system and pun an Intel sticker on it. And call it an Intel. ^^
SLK3000B
SS-400FB
SL-915GPro-FGR
BX80547PG3000F
PDC1G3200LLK
Why would some 915 chipsets have 64 bit support and some not? Intel isn't that stupid. Ever think the boards not saying they support 64 bit were probably made before Intel announced the 6xx series? Ever think to check Intel's site to see if their chipset supports their CPU? I did.
Originally posted by: cyberknight
isn't there an issue with the Intel 6XX series that you would need 4GB of RAM to enable the 64-bit extensions in order ot use Windows?
AFAIK all 9XX chipsets support EMT64 because the chipset has nothing to do with it? 😕
Can anyone point me specifically to a 9XX chipset that doesn't support EMT64?
Another important point that hasn't yet received much attention is support for EMT64, the name of Intel's 64-bit extension technology, which is essentially similar to the AMD64 initiative. Intel's documentation currently claims that EMT64 is only supported on the 925X. If that's indeed the case, and there is no way to add the feature with a BIOS tweak, mainstream users might find themselves out of luck once Microsoft unveils its Windows XP 64-bit Edition. Intel's Dan Snyder confirms that 925X is currently the only validated workstation platform with support for the Pentium 4 featuring EMT64. Whether the 915P will eventually incorporate the technology remains to be seen.
