Hi,
I have 2 routers
Router #1 is Asus N66U (used with my regular ISP)
Router #2 is Asus AC68U (used to run OpenVPN with PIA)
I have it connected like this:
Modem connected to WAN on router #1 (192.168.1.1), then LAN from router #1 connected to WAN of router #2 (192.168.2.1). I have given router #2 a static ip of 192.168.1.2
Each router is running a DHCP server. I cannot connect to either one with no issues.
I have a OpenVPN running on router #2 and everything works perfectly.
The problem I have is I cannot connect to any machine connected to router #2 from a machine on router #1.
I can connect to a machine on router #1 but I have to use the IP address because it does not seem to recognize the machine name. I would like to use the machine name but not sure what I need to do.
I enabled remote support on router #2 so now I can access the web settings page on router #2 from a computer connected to router #1
Please help
I have 2 routers
Please help
