Help with 2,000 Ford Taurus Mach stereo system
QueBert
22,983
1,179
Hi, I have a 2,000 Taurus with the Mach Audio System *YUCK!* I just invested a nice chunk of change upgrading it, but it still sounds weak. With all new speakers, a Alpine digital amp, Monster comp level wiring/plugs this is very annoying to me!
The problem lies here, the car has an all digital dash, I am looking for a replacement kit for it. All I seem to see is the Analog dash kits (they're everywhere) I'm going to assume since I called about 20 stereo places that there isn't a mainstream aftermarket replacement for the all Digital dash. But I'm also going to assume that there has so be some small company somewhere that produces these. *shrug*
My only other option is to adding a new deck (what I'm after) is to mount it under the passenger seat. Which is a last resort, unless somebody here knows of a Digital replacement kit, or possibly a better mounting spot. Oh and the glove box is a bit too small to mount there :(
any help/suggestions would be LOVELY!
AvesPKS
4,729
I have a 1999 Escort, and I was in sort of the same boat for replacing the head unit. The Escort has a similiar integrated radio/heat control unit; however, they are just 3 analog dials. I imagine you will have great difficulty replacing your head unit.
bmacd
10,869
i was going to mount a new HU in my glove box for security reasons and leave the stock HU on my explorer, but i opted not to.
-=bmacd=-
vi edit
62,484
8,345
Actually, you can get a replacement "oval" to fit around the dash and make everything match up after putting an aftermarket unit into an Escort. My buddy has a '99 scort and put in a Rockford MP3 player in his. The replacement dash was like $15 extra.
QueBert
22,983
1,179
oh the analog kit is EVERYWHERE!!! I only wish this POS didn't have the all digital dash. But if I can't find a aftermarket kit, I will find somebody who would be able to build me a custom one.
QueBert
22,983
1,179
Hummmm, my dash is one solid peice though, I don't think it'll be that easy! I talked to many stereo shops and all basically told me "you have 2 choices, mount a new head unit elsewhere, or you're screwed! :)"
vi edit
62,484
8,345
Sorry QueBert, my reply was more aimed at Aves. Just letting him know that he can swap out the head units.
