Elfear
Need some advice from you guys. I bought the Enhance ENS-0560G but I'm not sure how to distribute the 12V lines. From what I can tell, my components will be distributed like this (amp draw is approximate and I pulled it from this site and rail distribution I got from Enhance's site.):
12v1- Cpu1 (E6400@~12-15A when oced)
12v2 - Nothing
12v3- Motherboard (2-3A)
.........X1900XT (10-15A when oced)
12v4- DVD Drive (2A)
.........Sata Drive (~2.8A)
.........3x120mm (~2A combined)
.........2x80mm (~1A combined)
.........Sound Card w/ front bay (1.5A)
.........Water pump (50Z@~.75A)
.........Fan Controller (.8A)
I have an adaptor coming at the end of this week that will turn one of my sata plugs into two 4-pin molex connectors which will than be adapted into a 6-pin PCI-E connector. That will place the 2nd card on 12v2. For the time being however, I'd like to be able to run some 3D apps. I have no idea how accurate the Watt Calculator is so maybe the above requirements are way overboard. Any suggestions on where I can stick the 2nd X1900XT for now?
12v2 - Nothing
