Hi all...
I have VA-503+ mobo, I flashed to JE439 recently, it was fine (K6-2/350 cpu though). I then flashed to JE4330 and put in the K6-III+ CPU. I had it at 600MHz (100x2, remapped to 6 I guess), it reported as 552 or so MHz on the start up thing.
Well, now I can't get it to boot with that at all. The K6-2/350 will boot, but every time I reboot I have to take off the EP1/EP2 jumpers or unplug the power cable for 10s or so, then put it back, and it boots.. Otherwise when I turn it on I just hear the hd spin up and that's it, nothing comes on to the monitor and nothing happens afterwards (Even if I wait).
I downloaded a couple different BIOS updates from FIC's site right now, one of them looks like the one I'd need, but the "flash703" utility that it's supposed to come with, isn't in the zip file. The other one I downloaded, which MAY work but I'm not sure, has the utility required with it... WTF gives?
Anyway, I don't understand how it just stopped working like that. I checked everything... The voltage was set correctly, it wasn't set to Linear Burst (For Cyrix CPUs), I had all my sdram/clk or whatever jumpers set correctly (checked them over and over). I had it booting at 600MHz (BIOS reported 552 or so, but I ran Sandra, and it was PR602, and I was just under the Athlon 600 in score), but now I can't get it to boot no matter what, even if I take off the EP1/EP2 jumpers or anything, it just stays there and does nothing. With my k6-2 I can boot, but this thing is being a pain in the ass.
I guess somehow the bios is messed up because of the flash (I think it was a beta that I got).
So should I try flashing with one of the things I downloaded? Or does anybody here with a VA-503+ know of an update that works for sure?
PLEASE help... PLEASE!! 🙁
