help to OC 950
sergeex
10
I need a little bit of help figuring out how to OC my cpu to about 3.6~3.7 GHz
This is my first attempt to OC and I'm a bit nervous but willing to give it a try.
HARDWARE:
Motherboard: EVGA E760 CLASSIFIED "Overclocker's Pick" 1366 Intel X58
CPU: Intel Core i7 950 Code Name Bloomfield, Family 6, Model A, Stepping 5, Revision D0
CPU Cooling: Prolima tech Megahalems with 2 Scythe KAZE-JYUNI in push/pull setup
GPU: EVGA GTX 295
RAM: 12GB of Mushkin Redline DDR3 1600 PC3 12800 Cas Latency:6, Timing: 6-7-6-18, Voltage: 1.65
PSU: Thermaltake Toughpower 1000W
HD: Intel X25-M G2 80GB, 2 of them in raid 0, I run OS on that
OS: Windows 7 Ultimate
Here are some screenshots of BIOS
onboard PATA/SATA Device
http://i25.photobucket.com/alb...59/sayser/IMG_0089.jpg
AHCI Configurations
http://i25.photobucket.com/alb...59/sayser/IMG_0090.jpg
Maximum Payload Size
http://i25.photobucket.com/alb...59/sayser/IMG_0091.jpg
SmartFan Function
http://i25.photobucket.com/alb...59/sayser/IMG_0092.jpg
PC Health Status
http://i25.photobucket.com/alb...59/sayser/IMG_0094.jpg
Memory Feature
http://i25.photobucket.com/alb...59/sayser/IMG_0096.jpg
Voltage Control
http://i25.photobucket.com/alb...59/sayser/IMG_0097.jpg
CPU Feature
http://i25.photobucket.com/alb...59/sayser/IMG_0098.jpg
Frequency/Voltage Control
http://i25.photobucket.com/alb...59/sayser/IMG_0099.jpg
I have tried following the guide for OCing 920 to 4 GHz and that did not go well, pc crashed on startup and i had to reset the BIOS. I don't really want to push it to 4, but I think 3.6 or 3.7 would be
a more comfortable OC. I am absolutely terrified of messing with voltages and i need some input from pros here to guide me on OCing my rig.
Any input would be greatly appreciated.
I was thinking of lowering CPU Clock Ration to 22X and increasing CPU Host Frequency to 160. That should give me 3.5GHZ and Memory Frequency 1600MHz / 2:10 but decided to at least run it by you guys before i do anything.
