Just got the Phanteks PH-TC14PE from newegg this week http://www.newegg.com/Product/Produc...-pla-_-NA-_-NA and I may have already screwed (lol) myself.
My mounting screw seems to have stripped the threading on the heatsink. I have asked phanteks to send me an extra mounting screw because mine is obviously stripped, and I await their reply. But I don't really know what I am going to do about the threading on the heat sink.
Do you think I can just cram an over sized screw in there? Or maybe a self-tapping screw?
If you are not familiar with the TC14PE: the "Mounting Screw" is the only screw holding the heatsink to the mounting plate. This thread is very difficult to access, as it is on the aluminum base, between the two towers
, so I don't see any way to drill out the bad thread and retap it.
Is there anything I can do, or is this thing a paperweight already?
, so I don't see any way to drill out the bad thread and retap it.Is there anything I can do, or is this thing a paperweight already?
