Connoisseur
Hey guys, I recently bought an XP-M 2200+ 35w (AQYHA stepping) to replace my xp1600+ (o/ced to 10.5x162=1.7ghz) . I also replaced my Thermaltake Volcano 9 hs with the Thermalright ALX-800. When I stuck the XP-M in the first time, it got to the windows splash screen and shut down suddenly. I reset the cmos and went to default settings and when I loaded xp it says the cpu's at 600mhz (6x100fsb)! So I restarted, went back to BIOS and changed it to (10x multiplier and 200fsb) which this chip should EASILY handle. When I got out of bios it wouldn't boot. I reset cmos again and tried it at 1.667 ghz (the default setting for this cpu) and it still wouldn't post. It seems that the cpu can't do more than 6x multi no matter what!! Can anybody help me with this?? I have no idea what's going on. I'm pretty sure I installed everything properly as cpu temps are in the low 30's. My system:
xp-m 2200+ (at 800 mhz 🙁 ) w/ thermalright alx-800
Biostar M7NCD Pro
Crucial 512mb PC3200
480w Thermaltake silent purepower
3 hd's
2 opticals
Right now cpu temp is 30c and room temp is 40c.
HELP!!
Biostar M7NCD Pro
3 hd's
2 opticals
HELP!!
