- Jan 27, 2014
- 6
- 0
- 0
I want to setup a connection from 1 router to another with a distance of 100m(328ft)-200m(656ft) in between. I've done some research and found out that no CAT cable goes over 100m.
I found out that ADSL2+ however easily does and the speeds for my distance should be highest possible(almost).
Now my question, neither router has any RJ11 ports. So I was thinking of using this setup:
Router->RJ45 to RJ11 adapter->ADSL2+ cable ->Another RJ45 to RJ11 adapter ->Other router.
Would this setup work over a distance of maximum 200m? Would I get any (significant) data loss/speed loss? and would this setup work in general with the routers?
The adapters I was thinking of using are these ones: http://www.ebay.com/itm/310704843459
Sorry if any of this doesn't make sense, I'm not completely inexperienced with this.
EDIT: Also I'm open to any other suggestions of how to transfer data between 2 routers at a distance of up to 200m.
Thanks
Thanks
