Working on an Abit AX8 motherboard with AMD 64 3000 Winchester. Have a few configuration questions.
1.It appears that CPU FanEQ Control can also use the CPU, SYS, or PWM as the reference temperature. Are the SYS and PWM sensors built into the motherboard?
2.Will USB 2.0 support occur automatically after installing WXP SP1? Do I need to upgrade to WXP SP2 to obtain USB 2.0? Do I need to install any other driver for USB 2.0? The Abit manual said that the user must obtain USB 2.0 support from the service pack if using Windows XP.
3.I noticed that the BIOS at the ASUS website is listed is AX8 BIOS 10 Version 10 with a date of 2-25-2005. Is this the BIOS that comes with the AX8? The MB is AX8 V1.0. Not sure why these is no new release in almost two months!
4.The system comes with an AMD 64 3000 Winchester. I want to set the FSB speed to 250MHz with a CPU multiplier factor of 9X or 2250MHz processor speed. HOW DO I SET THE MEMORY DIVIDER to achieve a 5:6 ratio for a RAM speed of 208MHz (250MHz x 5 / 6)? I believe this is equilalent to LDT bus of 250MHz x 4.
5.There are two SATA processors on this motherboard to support up to four SATA hard drives. How would I go about in disabling the RAID feature in all four SATA ports? Does the VIA8237 chipset control the SATA1 and SATA2 ports?
TIA!
TIA!
