Update: SOLVED, Thank you Zepper[/B]
Antec Super Lanboy aluminum ATX Mini-tower case.
The Power On/Off button got stuck in the pushed-in position. Consequently the computer is unusable.
The entire button assembly is completely enclosed in non-removable aluminum sheet metal, on both sides, top, bottom, back. There doesn?t seem any way to remove the button from the case.
Therte isn't room around the sides of the button to slide something alongside it from the front, to pull it out.
Any ideas on how to fix this?
