Help Removing Stock Heatsink/fan from Geforce2
Dre
2,247
4
Can anyone tell me how to remove the stock heatsink and fan from a Geforce2? It's starting to make a lot of noise and I bought a replacement, but I don't know how to take off the old heatsink/fan. I tried pulling on it a little, but it looks like it's glued on there or something. Thanks in advance.
Dre
2,247
4
<< It's easier than you'd think. GO HERE for simple step-by-step. >>
That website won't load. I'll try it again later just in case.
Brian48
3,410
My mistake. I fixed the link. There's a few places in the LINKS section that cover this as well, but you'll need to sift through all the URLs.
