Soo I just got my mobo/cpu combo from monarch they install the cpu into the motherboard and check if it runs for you. I got the dfi nf4 ultra and retail 3000+ venice. Anyhow I'm trying to swap out the retail hsf to put in my xp-90. So I can get the clip without the lever off easily but the other side is a different story. I can push it down by cant move it out with just my fingers. I got a small screwdriver and used it to pry at it to push it out. If I use a lot of force (to the point where I'm scared if it slips I'd stab something) it would be at the very brink I think of being unclipped but wouldn't budge past. Is there some secret easy method I'm missing out on here? lol...
btw I undid the lever from the hooked position.
Ok got the clips removed. However its still stuck. Is the thermal pad adhesive??
