Help! Printer Question
CrimsonChaos
I am buying a new printer tonight! I am trying to choose between a high-end color inkjet and a low-end b&w laser. I really don't do any color printing, so was leaning toward the low-end b&w laser.
However, when looking at resolutions, the laser printers were doing around 2400x600 and 1200x1200... whereas the inkjets were all doing around 4800x1200.
First, I thought that laser printers had better print-quality than inkjets -- if this is true, why is the resolution lower for the lasers?
Also, when which number is more important, the first or second? For example, is 2400x600 better than a 1200x1200? Or is it the exact same? Which one would I want if I want sharper/crisper print quality?
Please advise!
The resolution is X x Y [horizontal x vertical] dots per inch.
In lasers you generally don't have dots as such.
If you are only printing text/greyscale, then laser will be much better and CHEAPER for you in the long run. Also, they have less of a habit of breaking down after 12 months and 1 week.
If you want a high resolution inkjet - you will only get that high resolution benefit when you print on glossy photo paper - and the prints will take about 40minutes for 1 sheet A4.
The ususal text dpi for an average inkjet would be about 600 x 600.
Always remember that the high dpi's put about for the inkjets are for photos. There is no way you would try and print on normal paper at that resolution. I tried it, everything came out smudged after an hour in the printer!
Thanks for the info - that makes sense.
What about the question regarding 2400x600 vs. 1200x1200 both on a laser printer. Which one is better - or are they the same?
Thanks again!
Never buy a printer without seeing a sample printout. The specs may look better on a printer with worse output
1200x1200 is better imho. But, I think you'd be hard pressed to find a problem with either. even at 600dpi text is very crisp on a laser printer.
I recommend taking a trip to Staples, or CompUSA and print samples.
I, personally use The HP Laserjet 1012
It's cheap, fast and excellent quality. I got mine for $150 last year at CompUSA.
There are several other good printers in that price range out there, but, this is what I went with.
I use both that laser and I use an Epson R200 for color. If you do a lot of B&W printing, laser is a lot more economical than ink. But, ink jets are really cheap to get excellent quality. $90 for the one I have, for example.
