Help printer choice
Coolharmony2
164
Hi,
Need help for printer choice :
I am hesitating between some All in one printers models :
Hp Deskjet 3510
Hp Deskjet 3520
Canon MX 420
Canon MX 515
Hp office jet.
I am searching for more reliability as possible.
Can you help me in my choice ?
For fax option, is it important to have 2 lines for the phone ?
I have only one line for the phone at home.
is it better to have a officejet model ?
Is it better to have ink cartridges XL type ?
Is it better to have individually ink cartridges for the colors ?
Is it too long to have 10 feet usb cable ?
Thank-you !
Mike64
2,108
101
hello,
is it better all in one laser printer ?
I don't print all the time.
Yes, unless you're willing to make sure you print at least a page or two every few days, if you don't print a lot, laser is much better than inkjet. Since you mention color, though, I'll point out if you want just a single printer to do everything and you need high-quality output, you'd probably have to spend pretty serious money to get an AIO with a "good" color laser printer...
As to the number of phone lines for faxing, it's totally irrelevant as far as functionality is concerned, but of course if you use the fax machine a lot, especially to receive faxes sent without prior notice, it would be a major PITA to have it sharing a voice line... Fax machines/software can be set to re-dial automatically until they get through, but you'll annoy a lot of potential callers who'll frequently end up getting a busy signal (and if they're business-related callers, will probably end up giving up, to your detriment...)
sdifox
100,462
17,950
Do you actually print colour? If not laser is a better choice. Look at the Brother multi function ones. some are duplex printing and have document feeder for the scanner if you need that feature.
