Help please with BIOS virus problem
Mydal
:confused:
Hi All!
I have a hard drive on another computer with a suspected BIOS virus.
I have purchased a new motherboard and am unsure how to remove the
virus without infecting the new motherboard.
If I boot off a floppy and then format the hard drive will this allow the
virus to get into the bios of the new motherboard?
A little perplexed as to how to go about this.. without killing the new
motherboard.
Thanx!
Buz2b
4,619
<< format\mbr >>
Well, in addition you will want to make sure that the boot disk you are using does not come from the old machine. Get one from a friend that has scanned his system and is virus free. Also make sure that it is write protected. Then proceed with the previously mentioned suggestion. ;)
