- Jan 20, 2008
- 522
- 7
- 81
It's been a while since I built a new rig and a lot has changed. Need advice picking a good DDR4 RAM kit for my new i9-12900K build, which is the last component I need to pick.
I've decided to go with DDR4 since I need 64GB and a DDR5 kit is just too pricey and wouldn't justify 2-3% performance gain over the DDR4. By the time DDR5 matures it will likely be time for a new build, so DDR4 it is.
My workloads are mostly productivity, software development, code compilation with heavy multi tasking, usually have tons of chrome windows with many apps in the background, etc.
Performance is important and I plan on overclocking the CPU, and RAM (if needed).
A few things have me confused like Single Rank vs. Dual Rank, Gears, would 2 x 32GB or 4 x 16GB be better, and DDR4 4000 being the max on Alder Lake.
Also, not sure if for my workloads I should prioritize Bandwidth or Latency.
Any advice on what I should look for or actual RAM model suggestions would be greatly appreciated. Thanks!
