I've got a Speeze WhisperRock II on the CPU. Idle temps in the case when I was overclocking at 400FSB and 2.31Ghz were 31 C case, and 48 C load on CPU. Right now, I've backed the system down to 333 FSB with the Mobile 2400+ overclocked to just 2.06Ghz. Current temps are 31 C case, 39 C idle CPU and 1.68-171 Vcore. Ran War3 FT for about 40 minutes without a problem--no more memory errors apparently. Also ran memtest86, after 4 passes, it didn't have any errors. So, it appears as though pelikan was right--the chipset was frying. Funny, because right after the last War3 crash, I felt the northbridge passive heat sink, and it didn't feel all that hot to me, just warm. Either way, I'm ordering the Iceberg for it. I guess my PSU is fine, but why is MBM5 showing that the +3.3 is steady at +2.54 volts?? And ectx, since you have anm 8rda+ also, where do you check your +3.3 volt in the bios?
