The saga continues.
The new 939 pin 3000+ processor arrived this morning. In it goes. Boots fine, windows looks reasonably good for no installed video drivers. No errors, no messages,very solid.
I reboot the machine into Memtest. Instant crash, just as before, Load, crash, Load, crash.
I switch to a different DIMM, same result. (This is 2 different 512 Mushkin sticks in Blue slot 2)
I add another of the DIMMS to Blue slot 1. Viola, the machine boots perfectly into dual channel mode, into Memtest and perfect , no errors, for two hours.
I try switching the dimms to black slots 1and 2, run memtest, 4000-7000 errors on test 4, in one cycle.
I switch processors and get identical results with all tests.
Now the machine is booting fine with either processor into windows but I still can't load the ATI video drivers. I've tried 3 different 9200 cards with exactly the same results. Drivers load fine, Windows asks for a reboot and the machine goes into an odd loop where it blacks out, restarts, shows the desktop momentarily, tells me that windows is going on stand by and restarts again. System restore fixes the problem, restoring to any time before the drivers are installed. Installing drivers in safemode doesn't work either. I've tried all 4 versions of the ATI drivers, all installs yield the same result.
So, I'm concluding that the processor is fine. Everything seems to be the same with either processor installed. The original processor runs a little cooler then the new one, but not by much, only 3 or 4 degrees celsius. Both work fine under fairly intense load, at least for short periods of time.
The ram slot thing is odd. Memtest won't initiate with 1 chip in blue slot 2, but the machine will boot into Windows. With 2 sticks in the black slots Memtest produces massive errors, but will also boot. With 2 sticks in the blue slots, dual channel works fine and Memtest shows no errors. The machine boots fine.
So, the big roadblock now seems to be the ATI card. My next thing will be to try any non-ATI card, maybe an Nvidia and see if I can get another card installed. I've tried tons of tweaking, apature, voltages, power, you name it, but nothing works.
Any suggestions or comments would be greatly appreciated.
