Well I've been out of the loop for a while and my current system is being pushed to the limit. I am still able to play BF2, but with all the setings at 0 or none or ugly, or whatever they are.
So I figured, that I'd like to see and play these games in all their glory and am ready to build a new box.
I'd like to stay in the $500 ballpark if possible.
I am partial to AMD, I've allways liked their procs and never had any problems, and from what I hear they are still the way to go, but am not closed minded on this.
After doing some research I think this is the video card I've settled on, once again open to suggestions: XFX GeForce 7600GT XXX 256MB
From my understanding I can SLI 2 of these together in the future if I need more umph, which means that I'd probably want a MOBO w/ 2 PCI-E slots... is that correct?
I have HD already, it is 150 gb IDE drive. Do I want/need to jump up to a SATA drive for my needs or will the IDE work just fine? I believe it is 7200RPM.
I also have a Case, but those aren't expensive anyway so I don't mind buying a new one.
And I also have a fairly new DVD drive so I'm good there.
Aside from that I need everythign else, so hopefuly you guys can help me out.
My goal is to play BF2 at the high setings without lag, naturaly, and any other current games on the market. At least, not have to drop everything to low in order to get a good fram rate.
Thanks!
Thanks!
