bob4432
- Sep 6, 2003
- 11,697
- 29
- 91
first off, welcome to the forums
if you want to play bf2 at high then you will need more gpu than a 7600gt and more than 1GB of ram.
case - use your old one, they may be cheap but even $30 here is going to matter
cpu - amd am2 3500 orleans - ~$90 CPU
ram - 2GB ddr2 667 - ~$140AR DDR2 667
m/b - nf4 am2 epox - ~$75 M/B
psu - 450W fsp - ~$52 PSU
gpu - x1800xt - ~$200 GPU
~$557 AR less shipping![]()
with this setup your performance will be nearly identical to mine and i game bf2 @ 1280x1024 all settings on high except shadows and lighting (i find them distracting) and get well over a very conservative 60fps all the time. no hiccups ever. and total ram usage goes up to ~1.5-1.6GB
So you are suggesting that instead of a 3800 I go down to 3500 and get a better video card instead? I just wanted to confirm that. Like I said, its 99% gaming machine, anything else I do with it doesn't really require a lot of beef. I'm also willing to go over $500, it's not a huge deal, should I do 3800 AND the x1800xt? Is the 1800 that much better than the 7600? I heard ATI wasn't doing so hot lately...
I'm really concerned with geting solid parts. I want to make sure the PSU is good and reputable, same w/ the Mobo. I've had good experiances w/ Epox in the past, so I do like them. I'm willing to spend a few extra bucs to get something good over something that might be suspect...
that is exactly what i am saying. if you can swing the 3800 and the x1800xt you would be set for some time. but if the budget keeps you at the single core then you will be fine with the 3500. bf2 does not take advantage of dual core or dual cpus. future games will. so even with a x2 3800 you will still be taking advantage of one core that is 2GHz and let the other core do all the other operations in the background. the 3500 will have a bit more speed on the one core, but it doesn't matter since you enough cpu either way.
ati works well and has for some time. in fact my last 3 gpus (9800pro, x800xtpe, x1800xt) have been ati. they have offered, imo, more bang for the buck. if you look at benches you will see that the x1800xt is = to a 7900gt, some instances the ati comes out ahead and others the nvidia comes out ahead (by a small %). so why not save some $$$ and get the ati
i am not a fanboy of anything except my wallet and the price/performance ratio for stuff i buy needs to be in my favor, not the manf![]()
If I decide to go 3800 is the Epox Mobo still the way to go?
i see no reason not too. if you are not sure about epox others can be found in the same price range. personally, i would buy it if that means anything.
