Hi!
I have the following mb:
DFI lanparty Pro 875(Rev A).
On the DFI web site it states that this motherboard can take up to P4 Prescott 3.06GHz processor. On the CPU compatibility list for the DFI motherboards on the same website it says that this motherboard takes the 3.2GHz prescott as well. Has anyone tried to run this mb with a 3.2 Prescott? Will it work or should I get a 3.06Ghz?
Another question I have is that again for this mb it says it can support up to PC 3200 memory. The thing is that I can find PC 4000 memory cheaper so can I buy it and put it on the motherboard and just work it as if it was 3200? Will the motherboard automaticaly run it at 400MHz or I will have any problems with the mb not finding any memory at all since this memory is faster than the top the mb can handle?
thanx in advance!
thanx in advance!
