Help OC a HD 7870 GHz
BallaTheFeared
8,115
Well I'm no expert... :\
But this is what I've been doing, this card is probably the most finicky card I've ever overclocked.
(MSI AB)
Then I start at the low end, because I disabled ULPS and Force constant voltage my card doesn't downclock/undervolt, but I don't want to waste power on the desktop or web so I create my first profile with the lowest possible settings for Profile 1. Then I go stock /w under volt for Profile 2, followed by another bump in core /w a decent vram overclock but nothing crazy I want to leave that voltage at stock and focus on core to start, and so on until I reach the upper end of what I expect to run the card in the most demanding titles as far as core goes. After I get those set in I go back and start tweaking the ram.
I do this with a list:
With my 7950 I've found so far out of about the 12 games/synthetics I've tested modded Crysis 2 was the hardest to run and really broke my voltage back. But that's really another matter, the point being start with a baseline in a decently demanding game (I chose BF3, across several maps) and go from there.
Once you get that done, then move on to tweaking your vram and making slight adjustments to voltage as needed upward for each engine.
I should also add I went with a 1C for 1% fan profile across the board, you may want to do something different depending on your preference. However if you plan to use it 24/7 in gaming do not set or allow the fan to go any higher than what you can tolerate for that need. Meaning don't set your clocks/voltages based on 100% fan speed, if you aren't planning to run it at 100% fan speed :\
Termie
7,949
48
www.techbuyersguru.com
Ironically, you are exactly one point ahead of my best score:
http://www.3dmark.com/3dm11/5930088
Our rigs perform identically when I'm at 3.5GHz on the 860 and 1175/1450 on the 7870.
what about oc'd
That's my max overclock score.
You're a bit ahead of me on the Fire Strike score:
Score: 5455 with AMD Radeon HD 7870(1x) and Intel Core i7-860 Processor
Graphics Score 6090
Physics Score 8455
Combined Score 2359
I'd say you're getting good performance with that overclock - hope you're happy with the 7870. It's a nice card.
Kenmitch
8,505
2,250
Playing around last night to see when my card craps out.
1200/1425
1250/1425
1265/1450
Guess it's not bad considering the rigs specs :)
The system:
i3-3225
His IceQ H787Q2G2M
MSI Z77MA-G45
8gb Samsung Super Ram
830 128gb SSD
1TB Hitachi
Asus Blu-Ray Burner
PC Power & Cooling Silencer Mk III 400w
Lian Li PC-A04B
I had no intention of playing games when I built the rig. I planned on running with the HD4000 video. I purchased the HD7870 as I wanted to play Tomb Raider and figured for the current price with the two free games it was worth it.
Durvelle27
4,102
1200/1425
1250/1425
1265/1450
The system:
i3-3225
His IceQ H787Q2G2M
MSI Z77MA-G45
830 128gb SSD
1TB Hitachi
Asus Blu-Ray Burner
Lian Li PC-A04B
nice scores
Kenmitch
8,505
2,250
nice scores
Your score is respectable!
Started Tomb Raider last night. Seems like a decent game so far. Using my son's old corded razr xbox 360 controller which he beat to hell and back. The buttons are worn out pretty good which makes it hard to controll. Want to keep moving in the direction I last moved....Son is a Halo whore!
Did you ever get your voltage unlocked?
