GprophetB
Hello everyone! Thanks for reading this post hopefully someone can shed some light on this weird problem.
Ok the build..
i5-750
Gigabyte GA-H55M-UD2H ( http://www.gigabyte.com.tw/Products...board&ProductID=3309&ProductName=GA-H55M-UD2H )
OCZ Obsidian 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
700 watt raidmax psu
normal sata dvd burner / 1tb hdd
Ok the problem is when it powers on all the fans spin up and everything looks good. But it never posts or beeps or... does anything... just sits there. No video no beeps nothing.
After some research i found that this motherboard only supports onboard video when you have a CPU that has integrated graphics on the chip. The i5-750 does NOT have this feature... so my question is would that be causing the system to not post at all? Or do we have a funk motherboard?
Three things it comes down to in my eyes
1) possibly bad motherboard
2) Needs video card to POST
3) PSU may be crap
*note i tried booting the system with 1 stick of ram, no ram, each dimm, both dimms etc... etc..
I also tested the motherboard outside of the case for shorts that would cause it not to post
All said and done i've tried nearly everything in my playbook and it still... wont... post
TIA
-GP
Ok the build..
i5-750
3) PSU may be crap
TIA
-GP
