i swapped my MoBo over from a KT133a Gigabyte board to the ECS K7S5A board.
i thought the board was in good condition, but .....................
i hit the power button, the CD-ROM light lights up (on for about 10 seconds then off then on)
the FDD light lights up & stays lite, but put a disk in & it doesnt try & read it.
theres no picture, have had the monitor flicker out of standby but not for long.
theres no keyboard lights at all,
the LAN cards' light flickers as per normal.
the fans are going
i unplugged all the IDE cables & the CD-ROM & FDDs' lights go on & off like a normal boot.
but above all theres no beep codes at all.
the speaker cable is plugged in , but no internal sound at all.
makes me things its set up ok, but cant get a picture or any beeps
i am beginning to think the board is damaged ????
anyone had this before ???
i have cleared CMOS too......
checked RAM & VGA in (often get caught there)
thanx for any help, bit of a rush to get my system up & running again , u know
the fans are going
