Help, need DOS compatible printer!
jjmIII
8,399
Hello eveyone,
I have an old DOS program at work used to run storage units. Running on Windows XP Pro 32bit.
I need a DOS compatible printer since the old HP Deskjet 610 has died.
I was looking at the P2035. link
Any suggestions? Will the printer above work?
Thanks -Jim :hmm:
cubby1223
13,518
42
86
DOS programs send their print jobs to an lpt port. The parallel port gets mapped to an lpt port by the bios. Or from Windows you can share a usb printer then map an lpt port to the share.
In summation, the printer you linked will work.
One company I work for we have the DOS program printing to a brand new Ricoh full size copier.
jjmIII
8,399
That's what I dont get. Like I stated above I have a perfectly working DeskJet 722C with a parrellel port mapped to LPT1 by default. It still won't work in the DOS program. I figured it would be "plug and play".
This guy seems to think the 722 has problems in DOS. Here - Partially Compatible Printers
That's why before I buy a $230 P2035 printer I want to be sure!
Thanks.
Evander
1,159
I've still got a Deskjet 693c in the closet from the DOS days which actually still works in recent Windows though I've only tried it on up to Windows Vista (using a printer port to USB cable). Good thing about those old Deskjets is the ink carts since several years ago can be found for dirt cheap. Actually, I used to get Staples recyle credits for almost the same as what I paid for the cartridges
cubby1223
13,518
42
86
Thanks.
I have an HP Laserjet P2015 and I can print to it from a DOS command prompt.
