I'm sure this is of interest to many people here - is there any sort of internet repository to help identify many of the most common files that might be running in the system tray (or whatever you call it when you press CTRL-ALT-DEL) in Win ME/98???
<systray> should be kept on (manages what's being used?)
<Explorer> should be kept on (if terminated - Windows shuts down)
THESE ARE THE ONLY REQUIRED FILES, I BELIEVE
HOWEVER,
<Rnaap> I'm not do sure about
<mdm> seems to show up after I open and close various programs
etc...
There are a host of others, and they work there way into my startup when I install things - I have to msconfig them out using a selective startup, but I'm never quite sure what they all do (esp. the ones residing in windows directories) and which ones are needed. All of them annoy me.
Additionally, my PC wants to load a bunch of things (e.g. LoadPowerprofile 2-3 times, taskmanager, etc.) that do not appear to leave a mark, but are these necessary? I can turn them off for my own comfort, but how do I really know what I've turned off (maybe I want them...)?
Any resources on the web, or general guidelines? I don't like Windows accumulating all of this crap and reducing my nice machine to slow error-prone junk-heap.
Thanks,
Andrew
HOWEVER,
etc...
Thanks,
Andrew
