HELP!! MY RIG DOESNT WORK ANYMORE
ofiraltarasy
910
i come home from school only to find that when i turned on my computer all that came up was the abit logo screen and i reset my BIOS and im leving it unpluged for a while, what should i do and it wont post HELP
Abit Fatility An8 SLI
AMD Athlon 64 X2 4200+
PQI PC3200 RAM 2BG
Antech Smartpower 2.0 500W
Radeon X700PRO
WD 250G SATA 3.0
acole1
1,543
No post errors? try stripping it down to bare minimum hardware (1stick of ram & video card) and see if you get any further. if it works try putting more parts in... if not, try swapping ram, video, etc.
good luck
ofiraltarasy
910
thanks thats what my friends said to do but i cant take out my cpu b/c i dont have any more thermal paste so i dont know what im going to do but thanks anyway
acole1
1,543
leave the CPU in.. just take out all but 1 stick of ram and the video. unplug the hard drive too.
acole1
1,543
you reset the bios properly i assume (move the jumper etc.)
This site says something about the error on the award bios... "05h Blank out screen; Clear CMOS error flag"
don't know if that helps any though.
I'm downloading the user manual but you can check in there and see if it tells you what errors mean what.
Edit: What bios version are you running? Here is the newest one.
acole1
1,543
LMAO thats what it was?! That's disgusting... so simple yet so problematic.
I wonder why that caused it....
