My 30gb hard drive has a bad track... its in the track 0.:Q I can't format it and windows wont load!!!!:frown: plz help me to fix this problem!!! what do i have to do!?!?! i'v don every thing i can think of!! 🙁🙁
well..first you can get a spare drive (go buy one if u don't have one), now load up OS of ur choice. If if you are lucky you can get any important data off you broken drive and transfer them to the new drive.
Provided that your partition record still stay intact (I think it still is)
