HELP!! My Ford Taurus has gone insane!!
LAUST
8,957
<< Volvo ==> Ford
That is why the dude had the same problem with his Volvo. ;)
Serious... Ford owns Volvo these days, if I'm not mistaken.
Door switch......... Prolly not made in a Ford Factory :Q
Chesebert
1,013
15
Thanks for all the info, I pulled the relay off so the lights won't drain the battery!
I am going to try some WD40 when I get home today...hoefully it will fix the problem.
if it doesn't, I think the lights relay will live in my glove box for a long long time :)
XMan
49
They will turn off automatically after 30 minutes. What you did won't hurt anything, but just an FYI.
tm37
12,436
Don't use wd-40!
It is highly corrosive! If your wiring has any nicks wd-40 will distroy your harness!
Use liquid wrench!
Silicon Based! Non corrosive
WD-40 Proof the top seller isn't always the best product~!
