My 24x Liteon burner burns everything fine, but while it burns, it uses 99%-100% of system resources!
Its so bad that sometimes it even has to activate burnproof when its the ONLY app running!
My friend has the same burner, but a faster computer, but it isn't taking up almost any resources.
granted, my system is a 366@523 and his is an AXP 1600+...............but isn't 99% resources a bit much? It takes 10 seconds for an icon to register that it was clicked on if I'm burning a CD.
Specs:
Win2k SP2
Liteon 24x
Celeron on a BX chipset
Burner is hooked up to the regular IDE port
system also has a Highpoint ATA100 card
hooking the burner up to the ATA100 card results in 60% cpu use when just READING a CD
on the normal IDE port, it uses 30% cpu when reading.
These numbers seem VERY high! My DVD drive only uses ~9% cpu when reading the same CD!
Help 🙂
Specs:
Win2k SP2
Liteon 24x
Help 🙂
