help my Chain tech av710
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,204
45
Originally posted by: noagname
those were the ones i was using but when i had put this one in it had some how worked
I'm confused.
So these were the ones you were using and then you reinstalled them and now it works?
Ika
14,264
Soo confusing.
Looks like he updated drivers from the Chaintech ones to the Via ones, but I can't tell from his nonsensical posts. Okay.
noagname
295
sorry i was very sleepy
so the thing is i had reinstalled them and input would work but it would not send it as output
YOyoYOhowsDAjello
Aug 6, 2001
31,204
45
You're saying "would"... does that mean the problem is fixed now?
SonicIce
4,771
just wondering, are u using high sample rate mode? cant record in that mode.
