Guys, it went flawlessly! In fact, this is my first post ever using my new system. I disabled jumper-free mode and set the DIP switches. Then I backed up the current BIOS (1003) then installed 1005, then enabled jumper-free mode. Then the mobo autodetected that CPU and everything is nice. I installed Win2k without a hitch; however I do have some problems currently.
I installed the network card and it worked correctly. I was able to access the Internet and run Windows Update. But now I get a page not found error for ONLY the Windows Update site. Every other site works. What gives? I noticed that this problem started as soon as I said "disable it" to a Unknown PCI Device (the network card). That doesn't make sense, since apparently it DOES work. It's also after I installed Service Pack 2.
Another issue, I made 2 partitions on my 120GB drive: 15 GB partition (C
for Windows and all my apps...and the remaining 100GB or so as another partition. My problem is that I can't seem to format that partition. I let it run in Windows, then 2 hours later it said "cannot format drive." I tried using a boot disk. Tried using the command prompt in Win2k as well but couldn't figure out the exact string to type. (format d: didn't work. it kept asking to use the /fs switch for the file system. how does that work?)
I appreciate your great help guys. I've gotten this far, but I still have a couple minor annoying problems.
