I am trying to hook up OCZ GameXStream 700W PSU with ASUS M2N32-SLI-DLX motherboard.
The mobo has a 24-pin EATXPWR connector, to which I connected the 20+4-pins MAIN cable from the PSU. MObo also has a 4-pin ATX12V connector. The Mobo literature says - "do not forget to connect the 4-pin ATX +12V power plug otherwise the system will not boot".
PSU has two more plugs named CPU1 and CPU2, both seem to have 4-pins. So there are total three 4-pin plugs on my PSU -
1) first is named 24 - this is with the 20-pin MAIN plug & i plugged it in EATXPWR connector;
2) second is named CPU1; and
3) third named CPU3.
What should I do? Please help!
