QueBert
I have Googled this and what I'm seeing hasn't helped. I got a Note 5 yesterday and straight out the box I'm having issues. Samsung Pay crashes when I try to open it. I would have been fine using Android Pay, but teh Googles doesn't let you use pre-paid visa's. Mine's reloadable and has my name on it, but whatever. I followed the few things I found on Google. Removed the update and ran it, won't open without me updating, updated and I get a Samsung account has stopped responding. Removed Samsung pay app and re-installed it, nope. This is a stock AT&T Note 6, running 6.0.1, I checked and there aren't any updates available from AT&T. But from what I read on Google the Android N update on this phone SUCKS. I don't know how the shit a stock Samsung app on a stock phone that has nothing else installed crashes every time, but it does.
2nd issue, after giving up on Samsung Pay (for now) I installed other things, now when an app needs me to set permissions, I get the annoying error that's putting me in the Apps that appear on top settings and I have to disable everything in order to be able to go back and change the permission. Then I can go back into the apps on top settings and turn shit back on. This is annoying as hell, and Googling's providing little help. I checked the 2 things I could find and they don't help. One was to check to see if 1 handed keyboard was enabled, and if so to disable it (it wasn't) the other said to just turn off all the apps on top. The main app I use crashes when it's disabled (Sliding Messaging) I'm not even sure why I need to touch these settings when I'm trying to do something unrelated like setting Shazam to be able to access my storage, but apparently it's the thing.
I would do my normal and install a ROM, but AT&T has this phone locked down tighter than an iPhone.
