Some facts that you need to be aware of.
1) 4K will only look good if the source material is 4K too.
If the source material is just 1080p or less, the image quality will be just as good as a 1080p image. Interpolation might sometimes make it look better, and soimetimes make it look worse.
1a) TV signal is 1080p at most. I don't think there are any cable or satellite companies that broadcast at 4k resolutions.
1b) Best DVD quality movies you can buy are still 1080p. BluRay. 4k DVDs might arrive soon. But they'll be expensive. And only new blockbusters will be available. If you want to download 4k movies, they'll be huge (tens of Gigabytes per movie).
1c) Almost all content on the web is made for 1080p or lower resolutions (phones&tablets). Webpages that have one or more pictures usuallly have them at 800x500 max or so. On a 4k monitor, all that happens is that the pictures in your browser will be two times smaller. The resolutions will not increase. Nice to have high ppi, but not when the picture is the size of a stamp.
1d) If you take pictures yourself, then 4k might make sense. If you have a 4k camera of course.
1e) Games.
Yes, many games support 4k. Or can be make to support 4k. But You shoudl realize this: 4k is 4 times the amount of pixels that need to be rendered. That means 4 times the work needs to be done. Your framerates will drop 75%. Actually, it's not that bad, because games do some work that is per frame, and not per pixel. But even then, expect your framerates to drop by 70%, 66% at best.
That is, if you have a videocard that has enough VRAM. You'll need more than 2GB VRAM for sure. 4GB seems to be enough at the moment, but that might change in the near future. But even if you have enough VRAM, do you have enough compute power on your videocard ? A gtx970 will be enough in older games. But not in the newest games.
Look at this benchmark:
GTA V on a gtx980ti.
http://www.anandtech.com/show/9306/the-nvidia-geforce-gtx-980-ti-review/13
27.8 fps for the gtx980ti on 4k with very high settings.
46.2 fps for the gtx980ti on 4k with only high settings.
Even with G-Sync that is not gonna feel very fluent.
My 3-year old gtx680 can do 46.2 fps on better than high settings on 1080p.
Are you willing to shell out top-dollar ($750+) for the videocard that your 4k monitor needs ?
Or do you prefer lower prices for 1440p or 1080p, while maintaining high fps and being able to enable more eyecandy ?
2) 4k Is still bleeding edge.
Look at these current stats from the Steam HW&SW survery:
http://store.steampowered.com/hwsurvey/
Look at primary display resolution.
1024 x 768 2.30%
1280 x 720 1.09%
1280 x 800 1.94%
1280 x 1024 5.69%
1360 x 768 3.02%
1366 x 768 26.33%
1440 x 900 5.08%
1536 x 864 1.69%
1600 x 900 7.82%
1680 x 1050 4.95%
1920 x 1080 34.54%
1920 x 1200 1.61%
2560 x 1440 1.11%
2560 x 1600 0.09%
2880 x 1800 0.01%
3200 x 1800 0.01%
3440 x 1440 0.04%
3840 x 2160 0.06%
5760 x 1080 0.06%
5760 x 1200 0.00%
There are 1.2% of Steam-gamers playing at 1440p. There are 0.18% of gamers that play at higher resolution than 1440p. One third plays at 1080p. Everybody else has a lower resolution.
So yes, 4K is bleeding edge. 1440p Can also be considered as bleeding edge. Anandtech is a website for enthousiast. What they do, and what they want, is nothing special. (It's all just bought in a store, nobody here builds their own technology). But it's still bleeding edge.
I've had a 1440p monitor on my desk for 3 days. The Acer XB270HU. Fantastic monitor. Unfortunately I had to send it back, because it is not very good when you play a lot of dark games with low ambient lighting. But it was very nice. The 1440p was more of an improvement than I had expected. At 1080p on a 27", I can see pixels, if I want to see pixels. During normal use, I don't see pixels on 1080p, only when I look for them. But on the 1440p, I couldn't see them, unless I put my face right in front of the panel. When I put back my old 1080p screen, it startled me ! So bad did it look. However, after an hour, I had adjusted again, and I don't miss the 1440p resolution.
Also, I didn't like my desktop and browser at 1440p. Yes, you can do scaling in Windows. But then defeat the whole purpose of higher resolution. I didn't like the smaller letters. Changing fonts didn't give me a satisfying result. And no matter what you do with your browser, webpages are just not made for higher resolutions.
My next monitor might be 1440k. Certainly not 4k. Hopefully the upcoming Acer Predator Z35 will be good. Only 2560x1080 resolution. But it has G-Sync, 144Hz and a VA-panel. A VA-panel should be perfect for me (good colors, high contrast, very good blacks). I rather have that than a 4k monitor.
In any case, before you buy a 4K monitor, you should see one with your own eyes. Maybe a 4K TV in a store nearby. That could give your a decent impression.
