Eug
- Mar 11, 2000
- 24,165
- 1,809
- 126
I'd rather have a good quality 300 W than an el cheapo 430 W any day. However, your choice of Antec for the 430 is a good one. If you want to go with Antec TruePower, why don't you just get a smaller one? It will be fine with the load, even if you add a couple of drives later. Hopefully it should be quiet too. It's rated quieter than the Enermax Whisper, but it still isn't a PSU that's really recommended for an ultra-quiet PC.
P.S. I just got an Enermax Whisper 350 W. Works fine, but the reviews are true. It's not as loud as the cheapo ones, but it's certainly not Whisper quiet. I ended swapping out the thermistor controlled fan for a Panaflo.
