Damn, I missed the bottom of the link lol
Originally posted by: AzNmAnJLH
<!-- Tschebyscheff said it, and I say it again:
There is always a prime between n and 2n.
...have a nice day...
-=[the creator]=-
Gotta find the source4.js file in your cache... I'm having problems finding mine.
'wget www.academy.dyndns.org/hackits/security_levels/source4.js' is a much easier method.
I know. I gave up trying to get it installed right in windows... I'll just reboot to linux 🙂
Installed? All you have to do is throw it in a directory and use it.
I tried that... It gave me some lbsomethine32.dll not found error. Rebooting is easier 🙂
-=[the creator]=-
What the hell? I cant figure this out either. Is their some hidden code?
John the Ripper is your friend, once you have the htpasswd file.Originally posted by: dighn
i give up on lvl15 (the .htaccess one)
The hint tells you want you need, that it isn't a hidden file.Originally posted by: dighn
how would i get access to that file in the first place?
Doesn't even start to get tricky until you're into the double digits.Originally posted by: replicator
This supposed to be a challenge? Just finished level 1 to 6 in about 8 mins
Still fun though.. One hint, Venkman!
So take the normal way you represent a .htpasswd file (.htpasswd), and make it not hidden.
-=[the creator]=-
I just did a save as from inside IE when the page was up. Worked perfectly.
-=[the creator]=-
Huh?
it works if you go english -> french -> german 😛Originally posted by: dighn
tip for last puzzle: don't use google's translator :|
Originally posted by: Radiohead
How do I find the code length for lvl 5?
