Help me clear up Thunderbolt 3 eGFX vs PCI performance difference
Status
Not open for further replies.
roger1-
Hi,
A rumor has been spreading on the Internet, that a non-eGFX certified PCI Thunderbolt 3 enclosure may be slower than an eGFX-certified one.
An example of a non-certified one is the Akitio Node Pro. An example of a certified one is the Razer Core X. Both released this year.
The only functional visible difference is that the Node Pro has a "daisy chain" Thunderbolt 3 port on it, that allows you to hook on more TB3 devices downstream - so practical!
Here is one reviewer talking:
https://egpu.io/forums/thunderbolt-...e-pro-thunderbolt-3-pcie-expansion-enclosure/
https://egpu.io/forums/thunderbolt-enclosures/akitio-node-pro-review-jack-of-all-trades/
Is there any substance in this?
Thanks!
One thread is enough to discuss your questions,
and there is no need for two. Please ask all of your
questions in your other thread:
https://forums.anandtech.com/thread...32gbps-aggregate-pcie-data-bandwidth.2551839/
AT Mod Usandthem
Status
