Originally posted by: MichaelD
*pffft* Got rice?
*pffft* Got rice?
*pffft* Got rice?
Really.. my car will probably outhandle your car any day..![]()
- not a ricer, beefed up the suspension tho 😉
*pffft* Got rice?
Originally posted by: theNEOone
oh yah, and just in case you didn't notice, 2 of the wheels are the 5-hole pattern, the other two are 4-hole. don't know if each model is offered in both drill patterns, but just a heads up.
*pffft* Got rice?
You are absolutely correct. Your car will outhandle my car. I have had TWO Civics in my life.
However, my truck weighs 2.5x what your car weighs, I can drive thru 24 inches of water and my tires come up to your side-view mirror.
Got insurance? 😀
Originally posted by: Howard
If you need to ask, the ones which are lightest (either by mass or on your pocketbook, your choice).
Don't like em. I'm looking for a more simple/clean look. I'm also going to be getting them in 15" sizes due to pricing of tires.
*pffft* Got rice?
*pffft* Got rice?
*pffft* Got rice?
Originally posted by: Quixfire
Number 4, plus I don't think adding rims to any car makes it a ricer.
Back in the days when I used to modify cars one of the first things we did was add aftermarket wheels. Back then it was called Hot Rodding, the only difference now is they work with 4 cylinders & V6s, and we worked on V8s.
Good Luck, they are getting rare. I had a 65 GTO that I was pro-streeting and ended up selling the car before it was done.Originally posted by: Imported
I agree. Just cause I have a Civic I wanna modify, doesn't mean it's rice. I mean, I'm looking for a mid to late 60s Pontiac GTO convertible to restore also. 🙂
