Originally posted by: drag
The Opteron, like the G5 and unlike the Xeons/Athlon/Pentiums, feature a memory controller for each CPU. This board allows you to have a independant bank of RAM for each CPU. This allows very large amounts of memory bandwidth.
Cheaper boards save money by only having 1 memory pathway. That means the CPU's have to share memory, like in a regular PC SMP setup. Which realy sucks.
It's crippling to the max performance the proccessors are capable of. The boards that only have one memory pathway typically can only support 8gigs of RAM, so it's easy to tell the difference. Boards that support 12 to 16gigs of RAM have independant memory busses.
Originally posted by: Lotec13
dual amd opterons (why easy 64 bit)
Dual Matrox set-up P-Gfx and RT.X100 (if you need more power go for a x800pro)
Two gigs of Ram Cosair makes a great two gig set
Tyan or MSI Mobo (tyan offers scsi on some boards)
3-4 main drives for raid level 5 or 0/1 up to you really
a 200gig or so back up Back up
A M-Audio sound card to get the best sound
and hey dual boot with a linux setup for a lot of good free (or close to it) video offerings
That should bring you close to the price of a good old mac G-fiver.
Also keep a eye out for pro monitors i just got two off of a lease and loving it
Originally posted by: mooojojojo
LethalWolfe, yeah, I guess it should be easier to design software on a closed platform. What I was wondering though is whether there is any PC which can do a similar 5-6 stream HD editing in real-time with no slowdown. Or perhaps it has to have dedicated video editing hardware to acheive that.
I just don't get it why most people on the forum recommend a PC for video editing when the Mac is the clear choice among industry professionals. And if the OP's friend decides to get a job in video editing, the Mac will most likely be the platfrom he'll be using.
The only thing that I can think of that could pull that many streams on the PC side would be an upper end Avid. Something in the $75k-$80k range maybe? I dunno, it's been a bit since I've priced an HD Avid.
Like I said in a previous post. You can edit on a PC. But doing it on a Mac generally provides a more productive, less frusterating experience. Almost everyone I've known who's edit on a PC for a length of time the switched to a Mac (usually to get their hands on FCP) always comment that they never realized how much time they spent hand-holding/fixing/managing/tweaking their PC until they started editing on a Mac and things "just worked." Are Macs perfect machines? Of course not, but in many instances (especially editing) they work right out of the box in ways that PCs don't.
The answer to your 2nd Q is just that this is a PC-centric board. I doubt very many people on this board have worked with/know that much about current Macs. Plus there are a lot of myths and stereotypes (for both Macs and PCs) that just will never die.
Even if your weapon of choice is a PC you still have to be "Mac fluent" in the entertainment industry because it is very, very Mac centric.
-Lethal
