Help me build a $600 computer.
It's For Sale / For Trade. If you go to the Main Forums listing, it's the third one down, under Operating Systems. Use with caution and always check the person before you decide to buy or trade with them. Do your research, and you should be happy.
Originally posted by: nitromullet
Originally posted by: GonzoDaGr8
That case and PSU sounds sketchy to me. Couldn't possibly be of very high quality.
I was about to say the same thing. The rest of the setup looks good though.
I would go for this case instead. It puts the price a bit over $600, but should be a much nicer case with a solid PSU.
I use a PowMax case and psu, they're both really quite stable and look nice too for the combined price ($45.00). Pictured here.
Serves me just fine and those bright bars on the front can be turned off with a handy little button near the USB/FireWire ports. But if quiet and humble is your thing, there are some low-priced Antec cases that will suit you better.
Are you guys sure that the Abit NF7-S can overclock the barton 2500+ to around 2.2 Ghz or at least near it? All barton 2500+ unlocked? Does the NEC 2500A burn 8x on 4x media? This is the pioneer A07 that I can get for $89 OEM, one of my friend has this same burner(pioneer A07), but it can't seem to burn at 8x on 4x media.
the Abit NF7-S is one of the best overclocking boards out there. if you really want to overclock then get a mobile barton 2500+ which only about $13 more than a regular barton 2500+. i have the mobile 2600+ but there's not much difference between the two mobile bartons. a 2500+ mobile can overclock just as well as a 2600+. i'm running mine at 2500 Mhz with a 200 FSB x 12.5 multiplier at 1.85v aircooled.
" shady only has 256 meg listed. 512 is the minimum lately. "
Actually its $59 each, 2x256. That's also stated in the post.
I'm not a big fan of overclocking. My exeperience has been that it's great for 3 - 6 months, then your board is likely to become unstable. The speed just isnt sufficient to justify that to me.
Also, based on what you mentioned you have slated, you've already got $110 of the $600 allocated so I was shooting for just under $500, which is what that setup comes out to. If you pop a Radeon 9600 into it, you get a price of around $550 and you lose the VIVO. You gain the ability to run DX9 3-D games pretty well, but it's overkill for warcraft 3.
If your main purpose is to rip DVDs and CDs, you would be a lot better off spending the extra $100 on some kind of RAID or SCSI setup.
