Good day all...
A strange issue began happening to my laptop.
All of a sudden it would switch to battery power and begin working of and discharging the battery - ignoring the power supply which appears to be working.
What is making it worse is that it will switch back to power for one second and then back to battery for one second and then back to power and keeps going on like this.
If I take the battery out it shuts down and seems to accept power just for one second and then as if though rejecting it, on an off like this...
At times after trying it will accept the power! And I can walk around the BIOS indefinitely, but as soon as I being booting up into OS - at safe mode exactly at load of "agp440.sys" it switches off! Why? Not enough power? But on the battery it is able to boot up fine!
If I walk around in BIOS with the battery in, it will charge the battery during this time.
If I attempt to calibrate the battery in BIOS (Charge>Discharge>Charge) at that request it will immediately begin ignoring the power and switch completely to battery after what it will die.
It kind of began after it was left in a laptop bag and it turned on and got extremely hot.
Looks like it is rejecting the power supply for some reason.
Where could be the problem?
Anything I can do to solve this issue?
It's a nice 3 year old Compaq X1000, running Win XP.
Any tips, tricks, links, suggestions are much appreciated
Thank you all...
Thank you all...
