Ok. I have a huge problem. I am building a PC for a friend of mine, and i think i broke the CPU.
System specs
AMD XP 2600+ -RETAIL
ABIT NF7-SG
512 gig ram.
80gig SATA HD
Pioneer DVR-108
Heres what happend, the Hardware install was going great, till I decided to put the retail HeatSink on. This is the first retail heatsink from AMD that i have seen with a lil Green tab on it.. could not get a Flathead screwdriver to fit in it.. so i had to struggle a LOT with it. It slipped off a few times.. my heart stopped.. i thought i might have crushed the cpu core or something.
Time to install OS, this was last night. It worked fine. Got OS up and running. Turned off computer, went to bed VERY happy that CPU was working. Came back home from work tonight, tried to boot up. I got to the windows screen, then computer decided to hang. So i rebooted, now I just get a black screen after the bios screen. I went into the bios.. CPU said 19xx processor speed.. ok good.. but FSB was at 100.. wtf. Shouldnt it be 333 for the 2600+. I only had the option of 100-200 fsp. So i rebooted.. now processor speed says 11xx. Woah.. thats not right.
So, does this sound like the processor busted? Could it be that after the first initial boot up of the processor, once it cooled down over night it just was too much stress for the maybe damaged cpu?
And since when did HeatSinks start having green little tabs on them? Do i need to buy a special tool?
I have been building computer's for 10 years now.. built about 20. This is my first one that I can not find the problem to. I have done all the normal testing.. pulling out each component... trying to reboot... starting over from scratch..
I only have one test left to perform.. remove sata HD and try regular. But it was working fine yeserday. I did not even have to install special drivers to get the sata working with this mobo.
BTW: I can not even boot up from the CD-ROM, like I could last night. And it is not a heat issue. Mobo reports CPU is between 34-39C depending on how long its been on. Sigh.
Should I order a new 2600+ XP and eat the cost? If so which heat sink should I get? Does not have to be great, just easy to get on and cool enough not to fry CPU
HELllllllllllllllllllp me !
System specs
ABIT NF7-SG
512 gig ram.
80gig SATA HD
Pioneer DVR-108
