T_Yamamoto
- Jul 6, 2011
- 15,007
- 795
- 126
A few thoughts...
Does anyone ever put felt or some other type of material to separate the brass standoff from the bottom of the motherboard? Would it be safe to do? This example is not exactly the same, but my current computer has these reddish brown paper rings that go in between the screw's cap (like a metal washer) and the top side of the motherboard.
Also, if my motherboard is shorting, what kind of damage is it taking? Should I just RMA the board now, hope that the replacement is damage free (If mine is even damaged?) and hope that a new board will fix the issue? I'd like to try some alternatives, but if I did RMA, that would take a lot of time. This is all just food for thought.
dreydin: I'll be playing TFC, Minecraft, and Diablo 3. I'm not a heavy gamer, so there's not really anything else on the horizon that I am interested in playing. Also, what is the difference between a 6950 and a 560Ti? Are there any great deals going on right now? I need to find some benchmark reviews.
mfenn: You definitely can increase the Vcore on the Pro3 Gen3. Check out page 44 of the manual for all of the voltage control options.
Odd, I removed a single brass standoff (went from 7 to 6) and put in 2 screws on opposite corners of the motherboard. Went to boot it up (inside of the PC case) and it worked. Then, I kept adding a single screw/booting/repeating until I had the whole motherboard secured with BIOS showing. I just added the GPU now and it is still working. The mobo has no differentiation between the holes for the standoffs and the manual says nothing about them. I'm not complaining, but it's a little weird!!
Ahh well, back to hooking everything up and managing the cables![]()
mfenn, any suggestions as to a good HSF for this build with air cooling(5x 80mm fans). I like all of my Rosewill stuff but is there something that will proove much better, and will the rosewill thermal paste I bought 6 months ago(sealed and kept in a good environment) be okay to use while going for a 4.6Ghz-ish overclock? And would my PSU be able to handle 2 Gtx 460's in SLI?
What an awesome build!hehheh i've got a similar setup that i just purchased. i lollerraped myself when i got it outta the most epic box ever? lolz mine was identical and im saving it as you most likely are lol. was wondering if you are overclocking? And did you update your mobo bios or not? I've left everything on my rig stock except boot speed stuff. Here are my specs:
CPU: i5 2500k(stock)
HSF: (Stock)
Mobo: ASRock Z68 PRO3 GEN3
RAM: Patriot Sig 2x4 DDR3 1600(stock)
PSU: Antec 650w Earthwatts
GPU: 1gb ECA GTX 460(stock)
Storage: Patriot Torqx 2
Haha, tfc was epic. You should check out ff (www.fortress-forever.com) if you have hl2, you can play this for free. If you dont have hl2, pm me and I'll steam gift you a copyanyway, the reviews on this site are the best imo, but you can find more on tomshardware.com
According to the chart on pg12, it is the top one in between the PCI slots and the AGP slot (letter B on pg10). It was slightly redundant, so I figured why not? Lucky guess, huh?There are 9 total mounting points for an ATX board (page 10). Which ones were giving you trouble?
According to the chart on pg12, it is the top one in between the PCI slots and the AGP slot (letter B on pg10). It was slightly redundant, so I figured why not? Lucky guess, huh?![]()
Hey, mfenn, what do you think about fan controllers? I'm not exactly looking for bling, but since my R3 case has a door that closes, I don't want a monitor that has knobs (forces me to recess the bay, which I don't want). I actually like the knobs because it reminds me of vintage audio gear, but I have my eyes on something like this right now > http://www.newegg.com/Product/Product.aspx?Item=N82E16811992005. The R3 does include a decent fan controller (image below), but the problem is the knob to adjust the speed is in the very back of the case by the PCI slots. This may even work if I don't have to adjust the speeds very often, but for the the time being I am seeing what my options are.
Haha! I was not originally able to find this document you have linked me to. You're absolutely right though, that is not an ATX location. This makes me feel a lot better considering how random the whole encounter seemed at first.Well, there's your problem! B is for MicroATX, not ATX. Note the table at the bottom of page 10.
Personally, I can't stand manual fan controllers, I'd rather hook all the fans that I can up to the mobo and let it control things automatically and 7V mod the rest. With a manual fan controller, you will honestly just find a position that you like and leave it alone. I have seen plenty of people with fancy knobs and buttons that they play with for a week or so and then never touch again.
So, I had all the components in place, everything hooked up, cables tied back, and finally went to start the PC... nothing. Nothing! I was about to give up for the day when my brother suggested re-seating the RAM. I didn't listen to him and instead pulled everything out to the original point where it had successfully booted last. Went to start... nothing! So I remembered my brother mentioning the RAM again. I did check to make sure they were seated, but I didn't actually RE-seat the RAM. So I tried this and went to boot... Bingo! It worked!? So I reconnected a single component at a time, booted, and each time it booted into BIOS.
Long story short; the new rig is humming
And I took your advice (when haven't I?), mfenn. I removed the stock R3 fan controller and hooked all the fans to the motherboard. I have adjusted all the speeds in BIOS and will do so further in Windows, if needed.
One loose end though. I have an old Razer Barracuda AC-1 sound card and I am not sure how to hook it up (other than connecting it to the mother board via PCI). Here is a picture of the available connections on the inside of the card. Are these necessary or relevant? I have a cable that connects in the CD-IN/AUX-IN slot of the card, but I can't find anything to connect it to on the other end (mother board or ROM). If I'm not mistaken, my old PC had a connection from the CD-IN or AUX-IN of the sound card to the back of the CD-ROM's "Analogue Audio" slot, which is not present on my new DVD drive.
Many thanks to you, good sir!Looks very clean :thumbsup:
The short answer to your sound card question is that you don't need to do anything other than plug it into the PCI slot. The longer answer is that the port labeled "front panel" is for an option breakout box that goes into a 5.25" bay. If you don't have that box (or don't want to use it), don't worry about it. The other two 4 pin connectors are indeed for analog audio, which would only matter if you have a really OLD CD-ROM drive and want to use it as a sort of standalone CD player instead of using a software application to play the music digitally via the data connection.
I'll do that!ya mirc costs like $5 or something, its been a while - just use icechat if you dont wanna pay
my alias is chef- - ill pm u my steam name. pw's to the servers are pickup.
hit me up!
