Originally posted by: JE78
huh?
I don't know, I don't think there was any static shock. Who knows. Thanks for your help, looks like I have some formating and downloading to do.
Originally posted by: exorr
Either:
1. You need to format the new hard drive in Disk Management.
or
2. Your secondary drive isn't setup as a slave. If the secondary jumper settings are set to master it wouldn't show up since there is already a master. You may need to change your jumper (usually there's a little diagram on the actual drive to tell you where to put the jumper to make it a slave)
Edit: A Warning: Do NOT change the drive letter of your drive that the OS is installed on. It can really destroy your OS.
For the guys that tried to helped me I wanted to say thanks. I got all my information back. After trying recovery programs left and right someone suggested Partition Magic. So I installed it, selected the drive that "had" all my important info on it, clicked on undelete partition and within a few mins my drive was back to normal. I can't tell you how releived I was when I saw all 150gb of info. So thanks for the guys that helped out.
