oh yeah heres another fun one... (copied from a now dead link from littlewhitedog.com that i resurrected from my history
Open up the mouse applet from the control panel.
Under the "button" tab, set the slider for Double-Click speed all the way to the right.
While you're in there, change the mouse buttons around for an extra kick.
Click "OK" and you're all set.
part2:
This little item comes in really handy when you change the mouse double click speed because the first place the user is going to go to fix the problem is the Control Panel right? Well, now we are going to remove the mouse applet (and other applets) from the control panel since most people won't know where else to launch them from.
Click "Start", then "Run"
Type in "Control.ini"
Towards the top, you should see a section header titled "[don't load]"
Under that section type in "Main.cpl=no"
Save the control.ini file
To see the changes that were made, you can either exit out of control panel and open it again or you can hit "F5" a few times to refresh it.
NOTE: Adding "Main.cpl=no" to the control.ini also removes the Keyboard, Fonts, and Printers applet from the Control Panel.
If you want to remove only select items from the Control Panel, I have taken the liberty of listing them below and what line must be put in the "[don't load]" section of the control.ini file. Enjoy.
Line In The Control.ini What Applet(s) Will Be Removed
"Desk.cpl=no" Display
"Modem.cpl=no" Modem
"Mmsys.cpl=no" Multimedia and Sounds
"Netcpl.cpl=no" Network
"Main.cpl=no" Keyboard, Mouse, Fonts, and Printers
"Appwiz.cpl=no" Add/Remove Programs
"Sysdm.cpl=no" Add New Hardware and System
"Password.cpl=no" Add/Remove Programs
"Joy.cpl=no" Game Controllers
"Timedate.cpl=no" Date/Time
"Odbccp32.cpl=no" ODBC Data Sources
enjoy
