Help! I need advice for Ideal Cooling and Power Options for this Build:
johny2314jj
282
What are the ideal cooling and power options for this build?:
Also , is there anything wrong with it, I am new at this, I am trying to achieve at least 60fps per eye in 1080p 3D for games like crysis 2, blackops, etc!
From Cyberpowerpc:
CPU: Intel® Core™ i7-2600K 3.40 GHz 8M Intel Smart Cache LGA1155 (All Venom OC Certified) [+84]
HDD: 120GB Corsair Force 120 Gaming MLC Solid State Disk [+205] (Single Hard Drive)
HDD2: 2TB SATA-II 3.0Gb/s 32MB Cache 7200RPM HDD [+119] (Single Hard Drive)
MEMORY: 8GB (4GBx2) DDR3/1600MHz Dual Channel Memory Module [+99] (Corsair or Major Brand)
MOTHERBOARD: [CrossFireX/SLI] Asus P8P67 Pro Intel P67 Chipset DDR3 ATX Mainboard w/ UEFI, DIGI+VRM, 7.1 HD Audio, BT GO!, GbLAN, USB 3.0, 2x SATA-III RAID, 3 Gen2 PCIe, 2 PCIe X1 & 2 PCI [B3 Stepping] [+75]
SOUND: Creative Labs SB X-FI Titanium PCI Express Sound Card [+103]
VIDEO: NVIDIA GeForce GTX 590 Dual GPU SLI 3GB 16X PCIe Video Card [+724] (Major Brand Powered by NVIDIA)
VIDEO2: NVIDIA GeForce GTX 590 Dual GPU SLI 3GB 16X PCIe Video Card [+799] (Major Brand Powered by NVIDIA)
Arkadrel
3,681
1000watts is too little...
1 x 590, can use ~350watts in peak load situations at stock speeds/voltage.
So you need minimum 700watts for 2 of them.... which leaves 300watts for the rest of his system? 1000watts is too little.
Question is if 1200watt PSU is enough? or do you need to use 2 PSUs to get above setup working?
(I think 1200watts psu, can handle 2x 590s + i7 2600k oc'ed, + rest of system)
Dont go cheap on the case, either (590s blow most of the heat back into the pc case), get a good quality one, something like the NZXT Phantom (Id consider that a good pc case) (so you wont have heat issues either with cards or with rest of your pc).
So probably recammend you get something like:
CPU cooler: (XIGMATEK Aegir SD128264)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233087&Tpk=Xigmatek%20Aegir%20SD128264
around 60$ but its a really nice cpu cooler. You can OC a 2600k @4.6+ ghz and still have it around the 60C mark, and not be overly loud.
PC case: (NZXT Phantom)
http://www.newegg.com/Product/Produc...-068-_-Product
PSU: (Antec High Current Pro HCP-1200 1200W )
http://www.newegg.com/Product/Product.aspx?Item=N82E16817438003&cm_re=1200w_power_supply-_-17-438-003-_-Product
cusideabelincoln
3,275
46
Why isn't 300 watts enough for the rest of his sytem? 300 watts would be plenty. The 2600k is a very efficient processor. The rest of his system would stay under 200W fully loaded. Also we're using rounded up figures here - to be on the safe side of course - and the figures are still adding up to less than a 1000W. So I'd 1000 watts is indeed the bare minimum for a stock build. If overclocking, especially the video cards, is taken into account, then he definitely needs more power.
I'm not saying he shouldn't get a 1200W PSU - in fact I recommend he gets the biggest one he can afford. I'm just saying, theoretically, a good 1000W should be enough for a stock 2600k setup. Note: Of course, not all PSUs are created and rated equally, so that's another variable that has to be accounted for. Brand and model is equally important as wattage here.
sandorski
70,677
6,250
Given that Heat is a concern, I think Air Cooling probably isn't the best choice. For the same price a Coolit or Corsair sealed water system can be had on sale and won't need to deal with the hot Case air.
Arkadrel
3,681
@Sandorski,
edit:
I think your right, he might be better off with one of these, alone due to the fact he can mount it on the outsides of the case and have heat deposited outsides the case.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181015
CORSAIR CWCH60 Hydro Series H60 High Performance ~ 74$
Might be a better buy or atleast equal, but keeping the cooling outsides of the pc case.
sandorski
70,677
6,250
@Sandorski,
because those "sealed" water system cpu coolers, you can buy usually arnt as good as the best air coolers. But I see your point, about not needing to deal with hot air in the case.... still the NZXT Phantom has pretty good air flow... Im guessing it shouldnt be a problem, and watercooling is usually a hassel.
Which "sealed" water cpu cooler would you recammend he get?
I'm no expert in them, pretty much any of them would do the trick though. H70 seems to be the best and sometimes an be had for about $60, although not often. Coolit systems seem easier to install.
johny2314jj
282
crap, so what kind of problems am i looking at in the future if i go with the default HAF-X fans and 1000 W psu?
johny2314jj
282
this is my entire build so far btw:
(cyberpowerpc)
*BASE_PRICE: [+715]
BLUETOOTH: USB Bluetooth 2.0 Adapter [+10]
CARE1: Ultra Enhanced Packaging Solution - Protect Your Dream System During Transit [+19]
CARE2: Professional Wiring for All WIRING Inside The System Chassis - Minimize Cable Exposure, Maximize Airflow in Your System [+19]
CAS: * Coolermaster HAF-X Gaming Full Tower Case w/ 1x230mm Red LED Fan, 1x200mm Fans, 2xFront USB 3.0 Port [+60]
CASUPGRADE: 12in Liquid Neon Thunder Pattern Light [+15] (Red Color)
CD: LG WH10-LS30K 10X Internal Super Multi Blu-Ray Rewriter [+104] (Black Color)
CD2: Sony 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive [+24] (BLACK COLOR)
CS_FAN: Default case fans
FA_HDD: None
FAN: Thermaltake FRIO Overclocking Cooler Fan (CLP0564) [+20]
FLASHMEDIA: None
FREEBIE_CU1: FREE Game - Shogun 2 Limited Edition Coupon: Total War
FREEBIE_RM: None
GAMES1: Crysis 2 Game [+59]
GLASSES: None
HEADSET1: Connectland™ Stereo Headphone with Microphone [+8]
IEEE_CARD: None
KEYBOARD: (Keyboard & Mouse Combo) Logitech Wireless Desktop MK320 Keyboard & Mouse Combo [+33]
MB_ADDON: None
MONITOR: None
MONITOR2: None
MONITOR3: None
MOPAD1: Razer Sphex Gaming Grade Desktop Skins Mouse Pad [+13]
MOUSE: XtremeGear Optical USB 3 Buttons Gaming Mouse
MULTIVIEW: Xtreme Performance in SLI/CrossFireX Gaming Mode Supports Single Monitor
NCSW: None
NETWORK: Onboard Gigabit LAN Network
NOISEREDUCE1: Sound Absorbing Foam on Side, Top And Bottom panels [+29]
NOISEREDUCE2: Power Supply Gasket [+5]
NOISEREDUCE3: Anti-Vibration Fan Mounts [+9]
OS: Microsoft® Windows® 7 Home Premium [+104] (64-bit Edition)
OVERCLOCK: Ultimate OC (Ultimate Overclock 30% or more) [+99]
POWERSUPPLY: 1200 Watts - Corsair Professional Series CMPSU-AX1200 80 Plus Gold Power Supply [+266]
PRINTER_CABLE1: 10-FT HDMI v1.4 Cable Type-A Male to Male High Speed Cable [+10] (2 pieces [+10])
RUSH: NO; READY TO SHIP IN 5~10 BUSINESS DAYS
SERVICE: STANDARD WARRANTY: 3-YEAR LIMITED WARRANTY PLUS LIFE-TIME TECHNICAL SUPPORT
SOFT1: McAfee AntiVirus Plus 2011 [+15]
SPEAKERS: None
SURGE1: Ultra U12-40629 7 Outlet Surge Protector Black 6 Individual On/Off Switch [+20]
TEMP: None
TVRC: Media Center Remote Control [+29]
USB: Built-in USB 2.0 Ports
USBFLASH: None
USBHD: None
USBX: None
VC_PHYSX: None
VIDEO3: None
WNC: Linksys WMP600N Wireless-N Dual-Band Adapter [+66]
_PRICE: (+3969)
_view_: d
johny2314jj
282
OK, I am going with 1 GTX 590 EVGA Classified, 1 i7 990z or 2600k Over clocked, 8 or 12GB 1600 Ram, 1 120GB to 160GB SSD, 1 2TB HDD, 1 DL Reader / Writer, 1 BD Reader / Writer, Coolmaster HAF-X, and the best mobo and psu for this setup. Also I want the system to run quite but I dont want water cooling. How should I do this? Cyberpowerpc? Custom Build?
