Help! i need a defragmenter utility for winxp!
fatbaby
Banned
May 7, 2001
6,427
I dl the trial version of diskeeper and ended up expiring...I uninstalled it and now windows acts as if its missing and won't run its own defragmenter, I tried looking for the utility on my winxp cd, no luck...
anyone??? diskeeper isn't free anymore, and a crack (earthquake) "won't occur"
Ameesh
23,686
one comes with winxp.
fatbaby
Banned
May 7, 2001
6,427
Yes, but where can i find it in the cd without reinstalling xp? I at first used the winxp defragmenter, then decided to tryout diskeeper, then my thingy expired and i can't get the winxp one back
alee25
828
ameesh: you post too fast without reading hahaa, the winxp defragmentor doesnt work because of the ending of the trial of diskeeper
Ameesh
23,686
try adding and removing the defragmenters through the add/remove windows compnenst in control panel
fatbaby
Banned
May 7, 2001
6,427
<< try adding and removing the defragmenters through the add/remove windows compnenst in control panel >>
i tried that, but i couldn't find the folder "system tools" in the add/remove part
Ameesh
23,686
<< ameesh: you post too fast without reading hahaa, the winxp defragmentor doesnt work because of the ending of the trial of diskeeper >>
yeah i just read the title,
god diskkepper is a piece of $hit if it breaks other peoples software.
ElFenix
102,407
8,595
dfrg.msc is the file windows has for defraging.
Colt45
19,720
dfrg.msc is probably in one of the .cab files on the cd... now if you want to go looking through the cabs is a different matter..
anyways.. go to run and try this:
%SystemRoot%\System32\dfrg.msc
if that doesnt work, search your windows drive for dfrg.msc. if it isnt there you'll have to find it on the winXP disk.. (in the .CABs)
manly
13,565
4,230
Guess what? Mickeysoft's WXP defragger is licensed from Diskeeper. And the commercial one is much better than the bundled version.
The real problem is that NTFS is a lame-brained filesystem that requires regular defragmentation.
